One For The Road
Hi All,
When for a ride today and noticed my voltage gage would fluctuate. I have never noticed this before. For the past few years (as long as I have owned it) the gage would read just over 14 volts. It did not matter what RPM the motor was running. It would stay at 14 volts. Today it would be as normal then every few miles it would drop to about 12volts then go right back up to 14. The bike runs and starts fine.
When I got home I used my DVM (one from Harbour Freight ... not their cheapest one) and measured the following.
Battery voltage with bike off ... 12.90 volts
Engine running at idle ... 13.90 volts
Engine running at 2500 RPM ... 14.05 volts
I ran the motor for a few minutes but the gage would not drop back to 12 volts like it did on the road. It stayed at just over 14 volts.
I left the DVM on the battery then shut the motor off. The voltage slowly dropped back to about 12.90 volts.
I checked the battery connections and they were tight. I have not checked any other connections yet and I have not checked the stator output. I need to read up on how to check that.
I don't know how old the battery is but it is a Odyssey Extreme.
Has anyone else had a similar problem ... or have any ideas what might cause this.
Thanks for your help.
Steve
Steve
