vibration
Discussion in 'Other Service and Maintenance' started by galxl68, Apr 2, 2015.
  1. galxl68
    galxl68 Member
    15
    I have a 2012 Electra Glide police. first chance to ride since I bought it in Dec. It vibrates alot more than my 2006 Softail I had at idle. I can also feel it when I let off the throttle and glide in gear. Can the motor mount be bad with 16000 miles?
  2. STEVE07
    4,128
    68
    86
    I believe that your softail had a B motor which has less vibration at idle and rolloff and also less power.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Your bikes drivetrain is all rubber mounted. The engine moves around a lot at idle, but smoothes out underway. Your softail engine was solid mounted with counter balancers inside the cases.
  4. Jeff Klarich
    4,844
    103
    496
    A 2012 with 16000 miles the mounts should be ok but keep in mind especially the front mount gets a lot of abuse and will deteriorate faster due to oil spills during oil changes. I agree with the above posts but it won't hurt to check the front mount periodically to make sure it's up to snuff.
  5. Jack Klarich
    [​IMG]
    #8 are your lower mounts, check the top stabilizer also
  6. galxl68
    galxl68 Member
    15
    Thanks for the help.
  7. dolt
    dolt Senior Member
    2,185
    103
    342
    Not likely that the front motor mount is bad but the later mounts are very stiff. Replace it with the Glide Pro front mount; it will make you smile.:D
  8. kdaddy
    kdaddy Active Member
    185
    38
    9
    +1 on the Glide Pro front mount. I started thread after changing mine out. Took about half an hour and cruising at 75 mine rides like a car.
