free website stats program Venting late style breathers | Harley Davidson Forums
J
Jack Klarich
Guest
In this picture #11 can be rerouted from the back of the air filter, you will need to drill a small hole thru the backing plate. Next attach hose to #11 and run thru new hole and run down the frame, you can run the hose behind the push rod tubes if you like, you will need to plug the hole in the back of the stock air filter, now all that oil mist is not getting sucked into your engine
I should have been a bit more clear#11 has a short hose in the middle, that is the one you want to remove and replace
