Vance and Hines Ovals..wondering
Discussion in 'Touring Models' started by Frederick J, May 14, 2010.
  1. Frederick J
    Frederick J Member
    5
    I changed my stock mufflers to Vance and Hines Ovals,do I need to install a power commander or any updates in this situation..wondering?
  2. Sirxamoc
    Sirxamoc Member
    8
    I just had the stage I upgrade done to my Ultra. It was well worth going the whole way. I had the 4 inch V&H slip ons, the Big Sucker air intake, and the ECM reprogrammed with the factory upgrade and all I can say is - It will make you smile!
    The power is definately noticeable and the sound is definately something that others will get a nod from. I had talked to someone that just did the pipes and he said it was OK but he did notice some power issues and backfiring. That is why I went the whole hog!
  3. HOLY DIVER
    HOLY DIVER Junior Member
    430
    yea you could get by leaving it alone.....but i think you would be ALLOT happier if you installed a TFI .....my thinking on this is TFI and stock pipes will work great, aftermarket pipes no TFI not so great engine will not perform up 2 par
  4. glider
    The TFI works very well with stock and aftermarket pipes as well as stage 1 . The only shortcoming for the TFI is a motor that has radical cams and headwork ETC.
  5. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    pipes + breather X tuner = :bananapowerslide: :bananapowerslide: :bananapowerslide:
    Might be a good time to treat your scoot to a few performance enhancements b/c you've already finished 1/3 of the equasion.
