I had a slight leak on my Dyna in the same spot. I tried some brand of ATF with "seal swell" to no avail. I finally determined my belt was too tight. With the properly adjusted belt the leak finally went away. But it wasn't overnight.
Pull the primary and replace the seals. James gasket kit is about $40. Its got all you need besides tools and some RTV, loctite, and will power. Might as well replace the shift shaft seal for $5 extra dollars whilst your in there.....
