Uploading Images
Discussion in 'Computer Corner' started by Joyflyin, Feb 4, 2018.
  1. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    6,050
    153
    251
    A lot of folks have reported issues trying to upload the images to the new forum. Although it may look like the mod team is quiet, we have been working behind the scenes with the forum administration team to correct these issues. Currently the status is that the forum only seems to be accepting 'image' files. This would be your .jpg/.png etc. Although when you go to attach a file, the options listed do show .zip, .txt., .pdf, .doc, .xls as well as a few other none image types of files, these files will not be uploaded at this time.
    And, when we do have the problem corrected, you will have to ensure that the file you want to upload is one of the types listed in the pop up window to choose the file.
    We will keep you posted of the progress.
    Thanks for the patience and understanding as we work out the new forum provider we had to move to recently.
  2. Jeff Klarich
    Jeff Klarich Experienced Member Contributor
    5,681
    183
    719
    Thanks for the update Joyflyin.
  3. dolt
    dolt Senior Member
    2,373
    103
    424
    .jpg files won't upload; haven't found any image files that will upload.:rolleyes:
  4. tourbox
    tourbox Senior Member Contributor
    2,014
    209
    STEVE07 likes this.
  5. SledDog
    SledDog Senior Member Staff Member Moderator
    2,148
    68
    92
    No luck uploading pictures. Still getting the same error.
  6. dolt
    dolt Senior Member
    2,373
    103
    424
    Just tried the tourbox trick; no love. Even if it had worked, way too much trouble to post a pic on a forum.:mad:
  7. SledDog
    2,148
    68
    92
    It's been solved.. Try it again...
  8. Joyflyin
    6,050
    153
    251
    Woot woot!!!
  9. D.Bradfield
    D.Bradfield Active Member Contributor
    160
    38
    23
    Finally!!!
  10. jamesearl
    jamesearl Well-Known Member
    2,631
    103
    443
    Parade Rest!
