free website stats program Upgraded exhaust and A/C - now I need a fueler! | Harley Davidson Forums
TQuentin1
Well-Known Member
Staff member
Moderator
OK. So this past weekend (4,340 miles) I did the following:
  • Replaced OEM air cleaner with SE Stage 1 A/C 50mm Kit (29260-08)
  • Replaced OEM head pipe with Powerflex Header (American Custom Exhaust Systems)
  • Replaced OEM mufflers with SE Thunder Slip-on 3 1/2" Mufflers (65115-10)
Now I need to add a fueler. I am going with the Dobeck EJK Fuel Controller - GEN 3, Part Number: 9120333. Should be just what I need until I add cams.
Cheers,
If you know you're doing more work, why not spend a couple hundred more now to avoid spending it later?
Could be a while from now, and I don't have time to fiddle with an SEPST or similar. Looking at the time and effort guys are putting into the more high-tech tuners (rather than fuelers), the Dobeck unit meets my immediate needs to richen up the AFR.
Cheers,
Good choice for now plus the discount, after cams a SERT or other that you can set timing would be nice:s
