J
Jack Klarich
Guest
FXR SUPER GLIDE
1 3787 BOLT 6 0.99 0.49
2 6192 WASHER 8 1.99 1.49
3 6703 WASHER 6 0.99 0.49
4 7229W LOCKWASHER 4 0.99 0.49
5 7629 NUT 8 0.99 0.49
6 8536 RIVET 4
7 8672 RIVET 1 0.49 0.49
8 9952 CLIP, CIRCUIT BREAKERS 4 17.99 15.99
9 11440 GROMMET 1 6.49 5.99
11 26561-84 OIL PRESSURE SWITCH 1 11.99 10.49
12 31506-79B STARTER RELAY 1 11.00 9.99
13 33043-80 WASHER, NEUTRAL INDICATOR SWITCH 1 1.49 0.99
14 33900-59 SWITCH, NEUTRAL INDICATOR 1 30.00 26.49
15 64511-63 WELL NUT 6 1.99 1.49
16 68537-89C TURN SIGNAL CANCELLER 1 150.49 132.49
18 70970-91 IGNITION PANEL 1 30.49 26.99
19 70979-86 ELECTRICAL PANEL 1 71.99 63.49
20 71424-83 BOOT, IGNITION SWITCH 1 9.49 8.49
21 71425-77 IGNITION SWITCH 1 71.99 63.49
22 71451-78 KEYSET, IGNITION SWITCH (SPECIFY KEY #.) 1
23 71518-80 SCREW WITH WASHER 1 3.99 3.49
24 71550-75 LABEL, IGNITION SWITCH 1 10.49 8.99
25 71552-75 FACE NUT, IGNITION SWITCH 1 4.49 3.99
26 71554-75 WASHER, IGNITION SWITCH 1 1.00 0.99
27 74589-73 CIRCUIT BREAKER 3 8.99 7.99
28 74598-73 CONNECTOR BAR, CIRCUIT BREAKER 1 4.99 3.99
29 74599-77A CIRCUIT BREAKER, BATTERY 1 8.99 7.99
16 68384-91 TURN SIGNAL CANCELLER (INTERNATIONAL ONLY) 1 78.99 69.49
