Brutal FXDX
Im planning to redo my bottom end this winter. My wheels are already out of spec. .007" runout on pinion shaft. I have an 02 fxdx w/ 80k miles. The question i have is can you use flywheels from 03-06 tourin or fxd on a 99-02 by removing the inner race on the sprocket shaft. 99-02 flywheels used timken tapered left side bearing and in 03 they made it a roller bearing. I have takeoff 06 touring flywheels w/ 10 miles on em and i plan to balance, lighten,true and weld crankpin on them IF i can just pull the inner race off and install timkin brng. Any feedback? Thanks
