Twin 88 Cam Cover Help
Discussion in 'Engine, Fuel and Exhaust' started by 2001FLHT, Jul 18, 2008.
  1. 2001FLHT
    2001FLHT Member
    35
    I have a 2001 FLHT with a polished aluminum cam cover. I want to replace it with chrome. My original cover is solid behind the derby, and the chrome one has a plastic plug where a wire was connected. Does that matter?? The bolt patterns are the same. Should I take out the plug or leave it in??Thanks for your help.
    50
    Cam cover and derby are opposite sides of the motor. Please clarify what you are referring to, I assume the cam cover. What plastic plug and what wire. There's no ignition parts in the cam side any longer.
  3. 2001FLHT
    2001FLHT Member
    35
    Yes its the cam cover, not the derby. The chrome one that I have came off a 2002 and it does have a plug that a wiring harness went on. That is the only difference. I didn't know if that mattered..
  4. Bud White
    3,270
    How about a pic?
  5. Fisher
    Fisher Account Removed
    341
    Early TC88s had cam position sensors.The cover will work with or without it.Bolt it on and shine away.Oh and you mean the timing cover.:D
  6. 2001FLHT
    2001FLHT Member
    35
    Thank you Fisher, You understood and answered my question.
    Safe Riding to you....
