Turn Signals Inconsistent
Discussion in 'General Harley Davidson Topic' started by cdyoung29, Jun 11, 2012.
  1. cdyoung29
    cdyoung29 Member
    38
    I installed a pulse brake light system from Kuryakyn and get a irrregular turn signal blink sometimes and a normal blink at other times. If I turn my signal off and back on it will blink at a regular rate. Any suggestions?
  2. gusotto
    gusotto Junior Member
    604
    38
    13
    Possible that the module is bad. If you know someone else with the module, see if swapping changes anything.
    Even if new, they can go bad.
    Kuryakyn has good customer service, give them a call.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    Is it possible the module is getting pinched between the seat and fender?
  4. cdyoung29
    cdyoung29 Member
    38
    I was not running the load equalizer because nI don't have LED's. I decided to install the load equalizer after some research and it fixed the problem.
  5. Bodeen
    4,643
    73
    221
    It good to get it sorted out and have done on your own. Job well done!
