Turn signal problem
Discussion in 'Sportster Models' started by harrisma2, May 15, 2012.
  1. harrisma2
    harrisma2 New Member
    4
    I am having trouble finding out how to post. I just bought a 2001 Sportster 883 and the blinkers are missing on the front. The left blinker do not work when i am riding. Also i must continue to hit the blinker switch to make the right blinker work when riding. What do i have to do?
    Thanks in advance!!!
  2. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Definitely use proper hand signals for now, but you have to get some front blinkers on the bike. Signal wiring works as a "system" and when any one is broke/damaged/missing it affects all four.
  3. harrisma2
    4
    2001 Sportster brake light and turning signal
    I just rode my newly purchased Harley 2001 Sportster around my complex and when i got home i noticed the brake light was out i assume because of the rattling. What can i do to correct this problem. Also i noticed that my right blinker has either a short or something cause it dont work when i am riding? Any solutions will help!
  4. harrisma2
    4
    Thanks i will do that!
  5. harrisma2
    4
    By the way thanks MSG, I am currently serving in the US Army!
  6. fin_676
    5,775
    153
    284
    Turn signal module is looking for the wattage draw from at least 2 bulbs before it will flash
    if the brake light is not working try changing the bulb 2 screws will take the lens off then twist and remove the bulb note the orientation of the posts on the bulb as it only fits one way
