free website stats program Turn signal install issues | Harley Davidson Forums
hdpratte
I have a 2005 road king classic. I bought it used, without any front turn signals or axillary lights. I bought hd light bar off ebay and have it mounted. Axillary lights work fine, but I can't get my front turn signals to work. I can get them to come on but will not flash. I'd appreciate any ideas.
Thanks
Are they stock bulbs or aftermarket? I installed a set of aftermarket LED's and without the equalizer they won't flash. If they are stock bulbs you may need to check the TSM unit.
Do the rear turn signals flash ok ?
the tsm needs to see the voltage draw from front and rear bulbs to start to flash
Do you have a wiring diagram? The stock bulbs are double filament. If you have them wired where they are on, that's the running lights. Turn signals are Violet for left, brown for right and will only flash, not stay on.
Note: I think, but am not positive that your wiring is same color code as '07 Electra Glide.
