Turn signal help
Discussion in 'Softail Models' started by Rick-e, May 28, 2010.
  1. Rick-e
    Rick-e Member
    18
    Right works, left doesn't. (front and rear lights both work, just don't flash)
    I found this using search Turn Signals - Harley Davidson Community
    didn't see any response as to what the solution was.
  2. Chopper
    Chopper Senior Member
    1,632
    19
    You might look at the front left bulb, the front bulbs are running lights and turn, maybe the turn filiment is burned out on the front?
  3. Rick-e
    Rick-e Member
    18
    Got it, I wiggled the wire to the bulb housing while the signal was "on" and it started working. It's either a loose connection in the socket or a a problem in the wire. Thanks for the reply Chopper!
  4. NEWHD74FAN
    8,191
    98
    19
    Rick-e, common problem moisture intrusion causes local corrosion. Disassemble each lamp, clean with cotton swab/alcohol or go to Radio Shack for Spray Contact/Tuner wash...dry, use clean pencil eraser or pen knife to polish contacts and coat with dielectric grease to prevent further corrosion.
    A couple months ago I parked along side another Harley and could see water half way up his turn signals...so this stuff does happen!
