true or false
Discussion in 'Oil' started by gunnut, Jan 16, 2011.
  1. gunnut
    gunnut Junior Member
    552
    I saw on tv recently some of the syn oils are animal fat/oils based,It doesnt actually say that on the contents list on the oil jug,and knowing how "accurate"tv researchers can be,I'm extremely curious as to what the constituants of syn oils really are,in a language I can understand.Having said that,I'm completely sold on them,and wouldnt use any thing else.I even use RED LINE 20-50 as a case lub when I reload.
    So, what say you guys??
  2. rancid
    rancid Active Member
    257
    never seen anything about that before, syn oil is generally a mineral base, modifyed with synthetic adatives, or synthesized from a synthetic compound. the easy way to tell what process is used to make your oil is to look at what API grade the oil is, which is similar to a dot rating for brake fluid.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I hadn't heard of this, but a simple search turned up lots of links.
    The oil debates will really get interesting now. Cheetah oil for racing applications, Whale oil for personal watercraft, and of course pig oil for Harleys. :bigsmiley30:
  4. glgarrett
    glgarrett Active Member
    203
    Let the games begin!!!
  5. Mainah
    Mainah Junior Member
    471
    And Mobil 1 makes the best french fries.:D
    Just kidding, don't try this at home!!!!!:rofl:rofl:rofl
  6. glgarrett
    203
    FYI... After buying my 2003 FXD back in November, I have become an avid reader of this site, especially in the lubes area because it is so critical. Took the bike in to my local H-D shop for 5,000 mile service and specifically asked for full synthetic engine oil, primary lube and gear oil. When I picked it up I was told (predictably) Syn 3 99824-03 was used in all three holes. Of course I intend to switch to Mobil 1, H-D Formula + and Spectro GL1 at the earliest opportunity. Thanks again for all the great information on such a friendly, valuable site.
  7. NEWHD74FAN
    8,191
    98
    19
    Using the OP analogy, you could say that "petrified" wood, a mineral is a wood product...TRUE..."dino" oil may have originated from animal and plant products, but has long since been changed, "cracked" and refined down to the molecular level so even trace amounts "natural" byproducts may not be present. :newsmile020:
    That said, 100% Synthetic goes a step further by developing a product starting from PROPERTIES of dino oil only all chemically synthesized (man made) in the lab (lubricating molecules identified & developed from scratch) starting out without any impurities like ash & inert materials found in dino oils...so FALSE... :s
  8. Dr.Evil
    Dr.Evil Junior Member
    694
    5
    It's Bacon !
    :bigsmiley8:
  9. porkchop
    porkchop Active Member
    220
    MMMMM.....BAAACON! Porkfat rules!!!!
  10. ultra...good
    ultra...good Banned
    302
    Did somebody say bacon?
