True Dual Kit 1.5
Discussion in 'Engine, Fuel and Exhaust' started by Bud White, Jan 18, 2009.
  1. Bud White
    3,270
    Didn't make it 2 since i managed to lose the exhust gasket so i couldn't finish so only 1.5 .. GRRRRR
    Ok well here is the right side pipe extension the part has been ceramic coated thats why it is different color. Heat shields will cover it i left them off to check for Exhust leaks ..
    [​IMG]
    After that add on the Slip on Torque everything to spec..
    [​IMG]
    Transfer your O2 Sensor to the new head pipe
    [​IMG]
    then remove the old Gasket and get mad as you can find the replacement gasket so your stuck .. well that ends it today
    [​IMG]
  2. Bud White
    3,270
    no i think not i would have had the pipes done if not for losing the dang gasket .. blah
  3. MexiRider
    MexiRider Member
    What kit is this?
  4. TQuentin1
    4,737
    142
    In another post on whether to reuse the exhaust clamps, we discussed the fact that those clamps ALWAYS break on a Saturday night or Sunday, so you need to have a couple of spare in your stash. These exhaust gaskets are another one of those we all have to have a couple of extra hanging around waiting for the inevitable!!
  5. Bud White
    3,270
    It would be the Fullsac Kit but i bought it from a local place
    TQ i order 10 froma guy that sells the harleys 10 for the price fo 2 that harley gets from ya i will have spares..
    As a side note i found it today in the snow standing on end.. where the snow had melted down to show it
  6. MexiRider
    MexiRider Member
    Been thinking of buying this kit. Have you heard if you need to remapp or get a bigger air cleaner? Local shop has never heard of this product and said that ANY change in the exhaust would require a bigger air cleaner, remapp, dyno tune etc. I'm confused and need more info. Thanks.
  7. Bud White
    3,270
    well i all ready have the bigger air cleaner and fuel tuner .. i would say a fuel tuner yes dyno tune no unless you have a Screaming eagle race tuner.. i use the TFI
  8. MexiRider
    MexiRider Member
    Thanks for the info. Ride Safe.
  9. Sgt York
    Sgt York Active Member
    140
    Hi Bud White. A couple of questions for you on the Fullsac. Did the rear head pipe smoke some after you got it installed? Mine does and I'm trying to figure aout if I have a leak or the pipe just buning off the new.
    What did you set the TFI at. I have mine at 2:30, 3:30, 3:00, and 4:00. Seams to be using nmore fuel.
    Thanks
  10. Bud White
    3,270
    yes it did smoke course it was 20 degrees when i first ran it i dont notice it now
    i have the green about 2.10/15 yellow closer to 2.30 this one is a big fuel user if dialed up and last 2 about the same as yours red might be 3.30 ish .. i have not yet finished fine tuning it as its to cold and haven't been able to ride anyways
