free website stats program Trouble codes | Harley Davidson Forums
Trouble codes
lonerider
Would a burned out brake light show a trouble code? Friend has a '03 Heritage Classic I sent him the instructions for retrieving trouble codes and he says he is getting a 6 or 7 trouble code ( can't remember) At the same time he noticed he had a burned out brake light. Could that be it?
Thanks Hobbit, that's the list I had. I'll have to check myself he did say it was either 6 or 7 (didnt remember). 6 is ECM and the bike is carbed so, it's not that. 7 is TSSM and he did hook up the run/brake/signal combo. I'm thinking when he said brake light he meant the signal light when he puts the brake on. Although I've never seen a burned out signal light set off a trouble code, just the quick flash. Sorry for the rambling I'm just thinking out loud.
2002 Low Rider FXDL
Jumped 1&2 and this is what I got; (numerous times)
12, 12, 11, 11, 12, 12, 12, 11, 12, 12, 12, 12, 12, 12, 12, 12, 11, 11, 12, 11, 12, 12, 11, 12,11, 11, 11, 11, 11, 11, 11, etc...
This went on for minutes.
Any ideas?
Current 11 TP sensor high
Current 12 MAP sensor open/low
Possibly a bad connection or water in the harness/plugs?
Quick question;
For an 11 code I should get flash pause flash, correct?
I am getting 12 flashes pause 12 flashes pause 11 flashes pause etc..
