02EGlide
Check engine light came on after the bike was started a week or so ago. Then I had trouble getting it started, but it started and I was able to pull it into the garage. I let it sit for about a week and went to start it today and it wouldn't start. I pulled the plugs and grounded them and I had no spark. Then I thought maybe the battery wasn't charged enough so I charged it for about an hour and it started up with the check engine light coming on briefly then going out. I decided to check the trouble codes and came up with 33 and then 24 and 25 which are combustion irregularities I attribute the 24 and 25 to having the plugs out and turning over is about the engine. The 33 code is about the system relay. Will a low battery cause these issues? Oh I forgot, its a 2002 flhtci.:bigsmiley15:
