Trike Jack/Lift Recommendation
Discussion in 'Trikes' started by SirDimsdale, Oct 19, 2011.
  1. SirDimsdale
    SirDimsdale Active Member
    181
    18
    Can anyone recommend a good reasonably priced jack or lift that can pick up the whole trike without having to turn my garage into a service station. Looking for something that can also be stored easily and does not weigh a ton. I know, I know I'm dreaming.
    Mike
  2. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    My table lift has extensions for trikes and is rated for 1650 lbs and lifts 43" high. It doesn't store easily though, takes up about a 2 1/2 by 8 foot space on the floor.
  3. SirDimsdale
    181
    18
    Geezer, what's the make or model #
  4. geezer
    1,709
    68
    73
    Tough questions Mike, you're testing my memory. I know it's a Ranger by Bendix. I'll do some digging and try to find the answers for you.
  5. R_W_B
    R_W_B Senior Member
    2,425
    23
    DimsDale what's the width and weight of your trike? There are quite a few ecomomical table lifts out there that if they can handle the weight you could weld on an extension to the table. Like Geeze said some of um have um already.
  6. HDDon
    5,561
    133
    236
  7. SirDimsdale
    181
    18
    The width is 54.30 inches and 1071 lbs weight. Ground clearance is 4.70 in. and length is 105.80 in.
  8. SirDimsdale
    181
    18
  9. R_W_B
    R_W_B Senior Member
    2,425
    23
  10. HDDon
    5,561
    133
    236
    Would this work?TRIKE ON A PITBULL MOTORCYCLE LIFT
