BOWHIKER
Junior Member
I'm getting ready to change my fluids tomorrow and have a question conserning the tranny plug . I did a dry run to see if i needed anything special . I tried a 1/2" drive 5/8 socket and couldn't get it on the plug because the shocks are so close together , then tried a 3/8 drive 12 pt. And still no luck . I was able to get a 6 pt. 3/8 dr on the plug so i know i can break it loose with that and then use a 1/4 allen wrench to run it all the way out . Can i use the allen wrench to break it loose and then use it to put it back in and torque it down ? Also since my torque wrench is 1/2" drive will i get the correct tourque using a 1/2 to 3/8 adapter on a short extension ? It is real tight quarters between the shocks , at least on my soft tail . At first i thought i'd have to loosen the 2 bolts on the back of the shocks to even get a socket up there .
