Transmission serial number
Discussion in 'Transmission' started by Rockdrummer, Mar 13, 2013.
  1. Rockdrummer
    Rockdrummer Member
    Does anyone know how to decipher the transmission serial number? I have found VIN decoders but nothing on transmission serial numbers. Thanks!!
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Let me know the numbers and year you think it is. I may be able to give you
    some info. You can use x's for the last 3 digits if you want.
  3. Rockdrummer
    Rockdrummer Member
    Will do. Thanks for your help. I will post as soon as I get home.
    Also I was wondering if on a bike where the engine and trans are original, should the serial number on the trans match up with the engine s/n or portions of the VIN?
  4. Breeze3at
    4,926
    224
    There is no match between vin and trans. number. From 2000 on the trans. number system was year then 6 digit sequential trans. number ie. 02 000123 would be a 2002 trans., 123rd built. An important part of trans.# is the style and location of numbers.
  5. Rockdrummer
    Rockdrummer Member
    Thanks for the info. The number on my trans is 01163374
