Trans Lube
Discussion in 'Transmission' started by leeanders, Jun 28, 2014.
  1. leeanders
    leeanders Member
    43
    Choosing between Spectro 6 speed Trans Lubricant - (or) - Red Line shockproof V-Twin Trans Oil -- What would be your choice and why?
    Thanks
  2. Jack Klarich
    Baker recommends Spectro, Redline is top also I have used Royal purple as well, less clunk and it holds up and does not shear
  3. dbmg
    dbmg Guest
    Either choice is a good one. Try one then next oil change try another. Both choices are top shelf.
  4. Bodeen
    4,643
    73
    221
    I have used both and wouldn't hesitate to use either. It would boil down to how available each is and secondly cost.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,924
    224
    Currently running Spectro 6 speed in my '07, it made a marginal improvement over the Mobil1 75/90 that was in it for less clunk and smoother shifts. I have a bottle of Redline on the shelf for next change. I sorta don't like the Pepto Bismol look of Redline that I've seen on disassembled transmissions, but I'm gonna use it.
  6. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I have always PROMOTED Freely Redline...
    I know that the ShockProof Heavy is designed For NO Metal To Metal contact...
    Using others JUST to see IF they work as well is a Waste OF time in my Book...:small3d023:
    Harley FINALLY says to change out the tranny at 20,000 miles...
    That said :::: IF your choice is not the best, 20,000 miles is WEAR that should not have happened JUST for trying to SEE...
    Take My word AND Many Others who use Redline Shockproof.... Heavy, Light Or the lighter product they make...
    Redline is the Best By Far.:rofl
    JMHO
  7. dbmg
    dbmg Guest
    Bubbie,
    Well stated. To add another thought, if you are changing your oil your self, the money saved, always change transmission and primary oils at the 5,000 mile interval. For we all know that peace of mind is priceless......:s
  8. dolt
    dolt Senior Member
    2,172
    103
    333
    Shockproof, hands down.:bigsmiley6: For the reasons Bubbie posted plus the additional benefit of being able to determine if a primary leak is from the tranny or the inner primary.:D
  9. Bodeen
    4,643
    73
    221
    Dolt brings up a great point about leak detection. No questions about it, if its red! I used it when I had a shift shaft seal leaking to determine the source.
  10. hillbilly81
    hillbilly81 Active Member
    368
    I went with the redline at my 5000 mile service and after reading up on their products I think I will go with their motor oil on my next service
