D dynowideglide Member Aug 25, 2013 #1 do i have to use harley davdison transmission fluid in my 1998 dyno wideglide if not what else can i use
harley@16 Junior Member Aug 25, 2013 #2 Welcome to the forum, lots of choices for oils. Check the self help section. No one specific oil is the only one. Just find something designed for the application who ever the manufacturer is.
harley@16 Junior Member Aug 25, 2013 #5 wrenchin said: There's no reason why you would have to use HD products. I have used Spectro gear lube for smoother shifting and quiet running. Gears need a gear lube. Spectro Platinum Heavy Duty Synthetic GL-1 5-Speed Gear Oil 75w140 1 Quart | Spectro Oils at Bob's Cycle Supply | Bob's Cycle Supply Click to expand... I've used it and recommend it too.
