G glider. BOT Machine Jun 12, 2009 #1 Here's the file on the problem with the touring swing arm holding water posted by "Freebee" Touring Swing Arm Touring Swing Arm Link 2
9FLHR Active Member Oct 27, 2009 #2 Once the hole is drilled in the cover, our troubles are not over! Checked mine today and saw a small piece of rust nearly blocking the hole. Fished it out, no problem. Just keep checking the hole to make sure it is clear. :cheers
