I have done this on several bikes. First you have to buy the brake,run, turn module from harley and then your turn signal and brake lights will be on the same wire if you run the wires to the tour pack after the run,brake,turn module
Thanks for the reply. I decided to add a Brake light module to the tour pack brake lights. Flashes about 8 times when I hit the brakes then steady brake light.
