Sgt York
My 07 EG tour pak did not come with side lights, so I bought a set from Crags List. Installed them and worked except two of the lights (LED?) on the right side. If I hit the light assy just right, they will come on. I figure it could be a loose solder joint or something that I might can fix.
The problem is how to separate the red lens from the housing. I see clips on it but when I pry them up the lens still will not come off.
Anyone knows how to get the lens off with out breaking anything?
Thanks
Thanks
