touchy back brakes
Discussion in 'Sportster Models' started by Painter61, Jan 16, 2011.
  1. Painter61
    Painter61 Member
    32
    I have bled my back brakes and still have a problem with some times they grab good and no play on the foot brake and some time I have a lot of play and have push down towards the bottom of the pedal:bigsmiley30:
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Sounds like the master cylinder needs to be rebuilt. Fluid is passing the cups.
  3. NEWHD74FAN
    8,191
    98
    19
    You might take a look at inspecting and possibly servicing the rear brake caliper, cleaning the external parts initially with clear water on a large towel (brake dust is hazardous, may contain metallic/asbestos bits). Then use pipe cleaner to clean around the exposed pistons as best you can, remove the pads and spray non-chlorinated Brakleen to wash the rest off (don't contaminate the pads if you plan to reuse them)...lightly sandpaper the linings and reassemble (pushing the pistons back into the bores). The key is keep everything clean, wash hands and area often.
    http://www.hdtimeline.com/brakes_tires_and_wheels/9868-replacing_rear_brake_pads_softail.html
  4. Safehaven
    Safehaven Active Member
    351
    I thought Asbestos brake pads were banned from the market since a while now. Does this still hold true for newer bikes? (OP has a `06 Sportster)
  5. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Not banned (in US) but phased out by auto Manufacturers. Ford used asbestos brake pads as recently as 2003 on some models. The OP may have aftermarket pads. It is still popular in aftermarket suppliers for brakes and clutch plates
    (car). It is usually marketed as "organic" not asbestos. It may be banned in other countries.
  6. fin_676
    5,788
    153
    287
    If i had the op problem of the brakes grabbing or needing a lot of pressure whilst using them i would strip the brake system from the bike an refurbish it a rebuild kit for the master cylinder and a good clean of the caliper i personally prefer to pop the pistons out of brake calipers when stripping and cleaning
  7. Jack Klarich
    Pinch off the hose to the rear brakes what does the pedal feel like now? If it still is weak best bet is rebuild or replace the master cylinder, this is a good test as you are taking the caliper out of the loop and only moving the fluid as far as the brake hose, give it a try:s
  8. elkhunter149
    elkhunter149 Account Removed
    134
    I would def. check master cylinder for pressure, make sure your front brake is working as it should, also check rear wheel alinment. If your rear wheel is not adjusted correctly it will cause your brake to spot:bigsmiley30:
  9. Safehaven
    351
    Good to know! Thanks for the info.
  10. jerryw618
    jerryw618 Member
    60
    6
    hi there did you lube the pins that the brake pads ride on ??? i forgot to do that and had the same symptoms , took brakes apart lubed the pins and groove the pads ride in and brakes work great now . its a step lots of folks dont do and causes bad brake action
