Torque specs for 2010 streetglide Primary Case Cover
Discussion in 'Touring Models' started by obchoice, Apr 2, 2011.
  1. obchoice
    obchoice Member
    7
    I know the torque sequence But can someone tell me the in. lbs. to torque the bolts on the Primary Case? I do not own a manual , it is on order, but still need to get the job done, any help would be appreciated. Thanks
  2. oiler
    oiler Active Member
    150
    My 09 SG manual says 84-108 in lbs or 9.5-12.2 Nm
  3. obchoice
    obchoice Member
    7
    Thanks for the Intel.
  4. NEWHD74FAN
    8,191
    98
    19
    Do use the lower torque settings and anti-seize compound (prevents two disimilar metal corrosion and galling). :D
  5. Jack Klarich
    And recheck the fasteners after a good ride just because:s
