Here's a few choices for tool kits as well as tire plugging kits for those that do a lot of traveling.
Plugging tires is only meant for a "get you home" and the tire should be replaced as soon as possible.
Also there are some dealers that will not work on a tire with SLIME used as a sealant because of the mess it makes on their machines.
H-D® - Snap-On® Tool Kit, 94684-00A
WindZone Essential Tool Kits
Sport Touring Tool Pouch ROADGEAR
RoadTech M3 Tool Roll
Slime Power Sport Smart Spair
Winning Pocket Tire Plugger
beza Windzone: Essential Motorcycle Tool Kits
With the newer bikes, there are some things that are difficult to repair on the road, but most things being electronic are best left to a professional.
Below I'll try to give you some of the things that would be useful for a tool kit for the road in case of a breakdown. This is what I carry.
A multi tip screwdriver (2 in 1) phillips and regular on the tips.
Spark plug wrench.
Pair of vice grips 6"-8" Or Channel lock pliers.
Set of torx bits (just the bits) preferrably ones that will fit into the multi tip screwdriver handle.
A multi tool of allen keys.(6-10 piece set in one tool).
Small set of 6 point wrenches.
Small 3/8 drive socket set, if you have the room.
A 6'' adjustable wrench.
Tubeless tire repair kit with inflator.
Spare fuses.
Pair of cutting pliers (side cutters).
A length of plastic tubing for "borrowing" some gas.
A dozen or so nylon zip ties.
Electrical tape.
A 10 MM wrench for the battery terminals.
Some assorted bolts and nuts.
A few different size hose clamps.
A few feet of safety wire to get you home if a cable breaks.
Emergency repair barrel for the clutch cable(has 2 screws that clamp the cable for a temp repair).
A 12 volt test light.
A small flashlight that works.
Some rags to clean up with also a tiny spray can of WD40 to use as a hand cleaner or a lube.
Most important is a cell phone when you find out you can't fix it.
Spark plug wrench.
Spare fuses.
Electrical tape.
