tire wear
Discussion in 'Wheels' started by moondog5150, Jan 30, 2010.
  1. moondog5150
    moondog5150 Member
    12
    have a 09 fatboy only got 7000 mi out of original tires.also about the same on my superglide.Is this about avg. talk to some and they say should get around 9000-10,000 just wonderin?
  2. fin_676
    5,779
    153
    285
    Tyre wear is all down to the conditions under which the tyre is used correct tyre pressure should be maintained at all times hard acceleration and breaking will reduce service life of the tyre
    if you are mainly doing a steady speed on an open road then your tyres should last longer if your hopping around town from traffic light to traffic light then youll get less miles
  3. moondog5150
    moondog5150 Member
    12
    makes since usually go to florida twice a yr. to work alot,quite a bit of local bar hopp'n with friends.
  4. dfbales
    dfbales Active Member
    143
    I have 12000 miles on my Metzeler rear tire, filled with nitrogen. still have 1/2 tread left
  5. Dr. Dolittle
    6,404
    118
    29
    Almost 12000 on my stock Dunlop front tire and still good to go!
  6. hogrotten
    hogrotten Junior Member
    642
    5
    :rider I'm aproaching 13,000 on my 08 FLHX (stock Dunlops) but probably won't get much more than that.
