Tire tubes
Discussion in 'Wheels' started by elkhunter149, Mar 24, 2010.
  1. elkhunter149
    elkhunter149 Account Removed
    134
    Wondering I you need to replace the tube on a spoke wheel every time I change my tire, which is every year?
  2. kemo
    kemo R.I.P
    1,690
    5
    Should change the tube and the rim strip when doing a tire change.
    kemo
  3. Jack Klarich
    Always a good idea here, Thanks Kemo
  4. jaceddie
    jaceddie Junior Member
    928
    For sure. It's worth it for the peace of mind.
  5. fin_676
    5,779
    153
    285
    Tube and rim tape are not expensive and the tyre is off so id change them i always keep a couple of old tubes laying around and whenever i need some thin rubber i just cut a bit off
  6. NEWHD74FAN
    8,191
    98
    19
    As Kemo & Fin said...learned this from bicycling for crying out loud...tires, tubes and rim tape are a blend of RUBBER, and takes only a couple years for rubber deteriorates not just on the skin surface, but internally. Just leave a rubber band, like a bungee cord strapped on the back of your seat under a bit of tension...turns into a crumbling mess in about a year or two. Do you really think a motorcycle setup used year around, or intermittant (which would extend the "wear out" component...would last "longer?" Trust me, if you still have the tires on after 5 or 6 years, check the sidewalls, if you see "checking" or microfractures but still have tread, change the works...sudden failure is not something to roll the dice with.
  7. ojonesy
    ojonesy Account Removed
    All tubes grow over time.
    When you reinstall a used tube you run the risk of the tube "creasing" on
    itself causing a blowout...not good on a motorcycle.
    Always use new tubes.
