tire presure
Discussion in 'Sportster Models' started by thewoff, Aug 10, 2008.
  1. thewoff
    thewoff Member
    14
    Im pushing about 80 H-P on my 1200N, even at about 20nph it will break traction what would be a safe presure to drop to and still be rideble? also the pipes I installed "nitemarz" from pipe-dreamz has blown out the right shock so anyone contemplating these pipes should consider, Im not too woried,because it wont efect anything once I put the motor in a softail style frame.
  2. dangerdan
    dangerdan Junior Member
    922
    Best advise is to use the recommnended presssure for that tire.
    Anything less could comprimise handling.
    Try a softer tire compound.
  3. glider
    I wouldn't lower the pressure for traction. In cars at the track, that's one thing but on a bike, lowering the pressure can lead to premature failure because of the heat buildup in the tire, not to mention the handling will be compromised.
  4. softailsteve
    softailsteve Active Member
    107
    I agree with dangerdan and glider go with a stickier tire (softer compound ) lower psi might not hurt on short trip down the dragstrip but on the street could be dangerous on a tubeless setup you don;t want the bead to come loose at high speed due to heat buildup .IS THERE ANY ROOM FOR A BIGGER TIRE
  5. thewoff
    thewoff Member
    14
    I'm going to use the frame from "atlas-Presicion" as for the pipes they exit about 2-3 inches from the shock.
