Tire Pressure 09 RK
Discussion in 'Touring Models' started by rklew, Mar 9, 2010.
  1. rklew
    rklew Active Member
    172
    1200 miles from home and I don't have my manual. I forgot what is the max air pressure on the front and rear tires of my 09 RK , 16" rear, 17" front. We are riding 2 up. Thanks for any replys. Lew
    36 front and 38-40 rear with two up.
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    LEW, my 09 FLHR calls for 36 front and 40 rear COLD tires.
    whats this Glider??? competition from the big boy?
    that PSSSSST sounds like a tire LEAK... better get it fixed...
  4. gunnut
    gunnut Junior Member
    552
    My wide glide has the pressures on the right side front down tube on the frame.HOPE YOURS IS THE SAME,FINGERS CROSSED.
  5. Hoople
    Hoople Account Removed
    7,198
    34
    Hear me out on this one::
    I think it actually depends on the brand of tire that you are using. Just went through this at the Metzeler Vendor tent at Daytona Bike week. The stock Dunlops that came on my bike require 30/36 solo, 30/40 with 2 up according to the HD user guide.
    Purchased front & rear Metzeler and now must run 38/44 in tires w/1 up. Metzeler insists you must run these pressures or all bet are off.
    I am thinking it depends on brand of tire and user guide quotes pressure for the tire that came on bike.. (? maybe)
  6. glider
    :newsmile011: Just trying to get back in gear again. Pssssst!:D
  7. BUBBIE
    4,974
    125
    i was thinking for the QUICK responses and his asking for a 09 FLHR ...... I FIGURED stock..... in my small book it says 36/F 40/R and also notes ALL MODELS....
    YES different tires and weights on them do call out for different pressures and I ,,,,, LIKE YOU HOOP,,,,, will go by what the manufacturer calls out for on them..
    I better be careful with the BIG BOY he packs a POOF! button
  8. Jack Klarich
    Always follow tire manufacture recs
  9. rklew
    rklew Active Member
    172
    Yep, my tires are stock and you are right on the pressure. Now that you posted them it comes back to me. :)
    Thanks for all the replys gang. :)
  10. NEWHD74FAN
    8,191
    98
    19
    Check decals near the steerer frame or in the swingarm area, as the inflation pressure for the stock wheels and tires are located ON THE BIKE. And of course Glider stated and you observed in the owners manual: 36 PSI Front, 40 PSI Rear for two up riding.
