Hello,
My next question.
I would like to tighten the rear axle in my softail evo. The rear wheel has older version of bearings - tapered roller bearing. In manual there is information that axle should be tightened to torque 60-65 ft.-lb. (83-88 Nm). But when I tighten the wheel to less torque, but without play, the wheel is rotating more lose than in case when I tighten to specified torque. When I tighten to about 84 Nm than the wheel is rotating a little bit heavily.
So do you have any experience with tightening axle with tapered bearings? Should it really be set to so much torque or maybe less. I have to say that I'm using loctite and moreover axle has a cotter pin so even if there is less torque it is no risk that nut will unscrew itself.
Best regards, Piotr
My next question.
Best regards, Piotr
