Throttle down problem
Discussion in 'Softail Models' started by Springer96, Oct 11, 2008.
  1. Springer96
    Springer96 Member
    5
    I have been having a problem with my 96 Springer jerking when I let off the throttle to slow down. The engine sounds a little uneven but fine when I stop and idle. I replaced the plugs and filter with no results. Does anyone have a suggestion?
  2. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    have you checked your drive belt tension?
  3. glider
    50
    Primary chain tension or final drive belt tension comes to mind.
  4. Springer96
    Springer96 Member
    5
    This is my first bike with a belt but there is very little play in it.
  5. wildspirit97
    1,088
    46
    I would then look into the "condition" of the belt then move on to the primary chain tension and go from there.
  6. Springer96
    Springer96 Member
    5
    The belt is in great condition. I will dive deeper. Thank's.
  7. glider
    50
    I would strongly suggest to get the HD factory manual.
  8. whatyardwork
    whatyardwork Banned
    829
    4
    Always happy to help out a fellow springer owner.Here's my 96.Primary chain adjustment is 5/8 to 7/8 in. with the eng cold.This is obtained threw the primary inspection plate.The nut should be re tourqued to 25 ft.lbs. and replace the gasket.Drive belt deflection should be 3/8 to 1/2 on top in the center with the axle tourqued to 65 ft. lbs. after adjustment.One question, is it jerking when you slow down or when you down shift.This isnt a Yamaha,you must get the revs up before downshifting or the belt will lock up.Those high revs you here from a Harley slowing down arent to make the rider feel cool.
    [​IMG]
