Those funny numbers
Discussion in 'Electrical' started by FLST, Mar 26, 2011.
  1. FLST
    FLST Active Member
    248
    4
    I have been studying schematics in order to gain a better understanding of the electrical system on my bike. There are many connectors and in the diagrams they are numbered e.g. [73A]. Are these connectors numbered on the motorcycle or they just for the diagram?
    I think you'll find the corresponding numbers on plugs on the bike but not ALL plugs.
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Like Mr. G says, maybe on some of the plugs but I have not see numbers on the Delphi connectors in my 2009. The cables start out with paper label tags on the wires that are near the connectors, but they fall off in time or they become un-readable.
    Life would be just too easy if numbers were on all connectors.:)
  4. FLST
    FLST Active Member
    248
    4
    Thank you Glider and Hoople. I guess that means tracing wires physically to find out where the connectors are if I don't already know. Doesn't sound too difficult. As an aside; Hoople, you have opened a whole new world to me with your simple and concise explanation of schematics. I'm having a ball studying something that used to thoroughly confuse me. The simplest things are, at times, the hardest to see.
  5. Hoople
    7,198
    34
    Now if only I understood it.!:)
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Modesty is your 2nd best trait (sparks being #1).:p
  7. glider
    I agree! :D
  8. NEWHD74FAN
    8,191
    98
    19
    I have found one advantage of the Clymer Manual is it has a COLOR schematic, which makes tracing the wires easier. Yes, their manual is $35 or so...but if you hunt around, it is worth the price of admission. I use it as part of my "carry on" luggage when going on long trips.
  9. ckphir0
    ckphir0 Member
    60
    I will be glad when they (clymer) comes out with a manual for my bike (2009 FXDL)
  10. rancid
    rancid Active Member
    257
    there is a table in the appendix section of the manual that tells you the location of connectors in relation to the number on the wiring diagram, ie under seat, left frame rail.
