TFI Unit mounting
Discussion in 'Engine, Fuel and Exhaust' started by cyborg, Mar 14, 2010.
  1. cyborg
    cyborg Active Member
    243
    Where is the best place, most conveniet, easiest to access the TFI unit? Under the seat or in the side cover on a `09 Dyna Super Glide Custom.
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    A little different on my 09 FLHR, I put it BEHIND the side cover LOOSE, wrapped in a NICE soft white shop cloth,,Then placing it INTO the ABS box that is there... I don't have ABS but the box is just a great place.. LOOSE is best for me as it can be moved anytime and stays there just fine...
    MOW,,, IF MY DYNA, I would ALSO leave LOOSE and PLACE under seat on all the other stuff there,,,, THAT is the SWEET SPOT in my book...
  3. cyborg
    243
    Thanks BUBBIE
  4. harleypr
    harleypr Account Removed
    96
    I have an 09 Deluxe but just for info I put it below the speedo until I had it adjusted were it worked best. The suggested settings were close. It was interesting to see it operate but too distracting for everyday use. I would think you could do the same.
  5. Grillfish
    Grillfish Junior Member
    652
    I've got an '09 RG and put it under the seat. Used velcro. Been there over 1 yr and never had an issue.
    [​IMG]
