TFI question
Discussion in 'Engine, Fuel and Exhaust' started by JPHarley, Feb 9, 2009.
  1. JPHarley
    JPHarley Active Member
    122
    I got my Vance & Hines Big Radius 2 into 2 and SE stage I air cleaner installed. I installed the TFI (1250 ST). I have the pots set pretty much like the suggestion; G at about 3; Y at about 3:30 and R at about 3:30.
    When I start the bike all the lights on the speedometer flash on and go off as they should. Then the Engine Check light comes back on for about 3 seconds and goes off and does not come back on. I've taken the bike out on a cpl of rides and haven't noticed any problems. Should I be concerned about this?
    Thanks,
    JP
  2. Bud White
    3,270
  3. glider
    50
    Good work Bud, maybe clear the code after logging it using that procedure and see if it returns.
  4. JPHarley
    122
    I ran the test.
    The first time I ran it I got this on the P
    P0261 Front Injector Open/Low
    P0263 Rear Injector Open/Low
    So I cleared it out and started the bike. This time each test said none.
    What I am thinking is that when I first put the TFI on and didn't have the connectors all connected and the bike didn't start is where I got the 0261 and 0263 code.
    Now that it is saying "none" on all the P S SP t....everything must be ok?
  5. JPHarley
    122
    Well that's great :D
    Thanks for the help guys. So now I'm off to fill it up to check the MPG.
    Thanks again for the help.
    JP
  6. Bud White
    3,270
    i would guess that was it
  7. glider
    50
    Sounds like you got the culprit.
