testing a voltage regulator
Discussion in 'Softail Models' started by philipk65, Sep 2, 2008.
  1. philipk65
    philipk65 New Member
    3
    I have a 05 fxst with just 1900 miles. Over the weekend while out riding the engine lamp came on and threw 3 codes. My warranty ran out 2 months ago and the stealership said there is nothing they can do. The codes were overvoltage. It sounds like the voltage regulator to me but is there a way to check this?
    Thanks
  2. dangerdan
    dangerdan Junior Member
    922
    Got this from the self help/search....Lots of good stuff.
    glider06-22-2007, 02:28 PM
    Step 1. First things first, load test the battery. Most places like Auto Zone will do it for free. Even if it measures over 12.5 vdc it can still be bad under a load. Battery is typically rated at 19 amp hours and 270 Cold Cranking Amps (CCA).
    Start the engine and measure DC Volts across the battery terminals, the regulator should be putting out 14.3 - 14.7 vdc at 3600 rpm and 75 degrees F.
    Step 2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
    To do this with a meter which is more accurate: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
    You may get battery voltage on all three pins on the newer 3 phase regulators.
    The no voltage is for older type regulators with diode indicating the diode is bad and the regulator needs replacing.
    Step 3. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for the TC88 32 amp system.
    Step 4. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
    Step 5. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
    Step 6. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if if passed step 2).
    Generally the following is true:
    Check your owners/service manual for the system amp output for your bike.
    22 amp system produces about 19-26 vac per 1,000 rpm, stator resistance is about 0.2 to 0.4 ohms.
    32 amp system produces about 16-20 vac per 1,000 rpm, stator resistance is about 0.1 to 0.2 ohms.
    45 amp system produces about 19-26 vac per 1,000 rpm, stator resistance is about 0.1 to 0.2 ohms.
    Also see here...
    Charging System Flow chart - Harley Davidson Community (Charging System Flow chart - Harley Davidson Community)
  3. glider
    50
    What a guy!:D
    Good work.
  4. dangerdan
    922
    All the info is here on this site, you just have to use the Self help and Forum Search engine.
    Thank the people who run this site. Their knowledge is priceless.
  5. glider
    50
    Thanks for that Dan. Glad to help out.:D
