tank swap for '91 XLH 1200
Discussion in 'Sportster Models' started by cfcolby, Dec 27, 2010.
  1. cfcolby
    cfcolby New Member
    I just bought my first Harley, a '91 XLH 1200. I want to put a different tank on it that has the speedo mounted in between the split tanks. I see alot of tanks on eBay that I like but they come off different models. Are there any tanks that are a direct swap or easy change?
    Thank You,
    Craig.
  2. fin_676
    5,775
    153
    284
    There are a few different tanks that will fit your needs but they are one piece tanks and have a cut out area so that a console can be fitted and they can be bought as a single unit complete with everything but they are not cheep
    They are available from zodiac and custom chrome they may be available elsewhere but my shopping choice is limited due to location
  3. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    I have put 2 large tanks on XL's, but they were both made for XL's. Like Fin said, not cheap. Try searching for "xl or sportster tank mounts" or something like that in ebay. I have seen many mount kits, but haven't paid attention to the specifics. Some one must make a kit to fit split tanks to an XL.
  4. Jack Klarich
  5. fin_676
    5,775
    153
    284
    That setup is what i was thinking of and it is a lot cheaper your side of the pond
    Fitment says will fit 95 and up but i think it will be ok on earlier bikes petcock moves from right side to left so the outlet will point forwards rather than backwards and you will need a longer fuel pipe from petcock to carb the other area of slight concearn is the speedo 95 had electronic and i think the phsical size is about the same (but not absolutley sure) and the speedo cable will have to be re routed but length should be ok
    You may have to make some custom wiring to move the warning lights to the tank consol
