switching gas tank??
Discussion in 'Softail Models' started by 19fxsts91, Jun 25, 2012.
  1. 19fxsts91
    19fxsts91 New Member
    i have a 91 fxsts. i want to change to a solid tank, for the gaudge & would also like to add a lift. I've seen tank & fender set for sell on ebay. does anybody know if a newer model (say a 06) would be able to be exchanged for mine if so what modification would i have to do to accomplish this?
  2. Jack Klarich
    Welcome to The Forum. If you can lay your hands on a P arts and Accessories catalog you could look in the paint section under the sheet metal, it should give you the specs on what year tanks will fit
  3. fin_676
    5,789
    153
    288
    I do not think any one piece tank will fit straight on and you will need to change some of the dash stuff also as the dash stays on the bike when the flatside tanks are removed on a one piece tank the dash is mounted to the tank
    However anything is possible with modifications it is just how much time effort and money do you want to spend
