Have a dealer check the VIN as Joel suggests. If that doesn't turn anything up, run a compression test. If the top end was a 96" and converted to 103" CCP will be higher. A 96"er will pump about 180psi but a 103"er will pump about 195psi. That is assuming all other components are stock, i.e., chamber volume, piston dome volume and cam timing.
