Stock settings for a TFI
Discussion in 'Engine, Fuel and Exhaust' started by Redfish-Joe, Oct 24, 2009.
  1. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    Anybody have some good numbers for the TFI on a box stock (for now:s) 08 Road Glide? Thanks!
  2. Bud White
    3,270
    start with what they recommend and then turn pot#2 the yellow light off .. back the green up just a tiny tiny bit and go from there.. the setting they give you in the paper work are on the rich side.. #2 pot is where a lot of your gas milage goes i have had mine turned off for awhile and dont notice a difference.
  3. Redfish-Joe
    2,307
    10
    Thanks Bud. Let you know how it goes.
    Got it installed and set . Went a mile or two down the road. Smoother idle and crisper throttle responce:bigsmiley24:
    I'll ride tomorrow and see how it does. May have to tweek a little.
  4. Bud White
    3,270
    remember to get a valid Fuel milage run .. you have to control right hand
  5. Redfish-Joe
    2,307
    10
    220 miles today. Mileage is at or above 42mpg. I have 3 more to install when they are ordered:lolrolling
  6. glider
    50
    Now Joe, installing 3 more isn't going to triple your MPG :D
    Very good MPG too.
  7. Bud White
    3,270
    yep good mileage there im getting just under 41
  8. glider
    50
    That #2 pot is the one that knocks the mpg down and can be turned almost off.
  9. Bud White
    3,270
    I all ready said that :) but i said turn it off i dont notice a difference at all with it off other than gas milage goes up
  10. glider
    50
    I think the #2 pot is overkill being the fuel map and the TPS can add fuel to the mix without it.
