stock or lowered...
Discussion in 'Sportster Models' started by usafhg7, Nov 7, 2011.
  1. usafhg7
    usafhg7 Member
    18
    Which do you prefer... stock height or lowered?
  2. Jack Klarich
    Your ride you decide Lowering Shocks - Harley Davidson Community here is some good reading, you can use the self help section here for more on suspension. I have lowered 2 baggers IMO I would never do it again JMO:s
  3. usafhg7
    usafhg7 Member
    18
    the only reason i ask, is because when you think Harley Davidson, you think gliding down the highway not a roughish ride. mine is lowered already, but what if i brought it back up? would the ride improve?
  4. Jack Klarich
    You would be back @ stock ride height and the handling would be improved, especially when riding 2 up or loaded with gear
  5. glider
    Stock height for me. Only one that was lowered and I wouldn't do it again.
  6. usafhg7
    usafhg7 Member
    18
    Should I raise it back up for a better,smoother ride?
    [​IMG]
  7. glider
    That's your choice but the sportys ride a bit rough either way.
  8. Bodeen
    4,643
    73
    221
    Stock. If I were short I would consider lower but that would be the only reason.
  9. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    JMO, but I never was a fan of lowering bikes...just doesn't look right (Shriner Clown). If you elect to raise bike, might want to look at good set of shocks...like Progressive...
  10. dbmg
    dbmg Guest
    Stock all the way. Best ride and handling as bike was designed for.
