still no fire,changed everything i can think of
Discussion in 'Other Service and Maintenance' started by hdfatboy02, May 15, 2010.
  1. hdfatboy02
    hdfatboy02 Member
    I have a 2002 fatboy and it won't start. Checked for fire and it has none. So far I changed the crank sensor,coil,start relay,and plug wires.Does anyone know what could possibly be the problem?
  2. Bud White
    3,270
    since its a early TC does it have a cam sensor in the nose cone?
  3. hdfatboy02
    hdfatboy02 Member
    no cam sensor
  4. Bud White
    3,270
    look for breaks in the wiring somewhere then would be the next best guess
  5. hdfatboy02
    hdfatboy02 Member
    I will go through the wires again and look for a break.I can't think of nothing else to do.
  6. HDDon
    5,543
    133
    229
    Did it just start or was it running ruff before? Did you wash it and get water in the switch areas? How did you check the coil, do you have a new starter relay. Does it turn over, with no spark? Try to give as much info as you can about when it last ran and anything you have added or taken off the bike.
  7. dhorne
    dhorne Active Member
    258
    have you checked the ignition?
  8. Jonas
    Jonas Junior Member
    408
    It's carbed right??? If so I would go on ebay and buy an ignition module. Even if it turns out yours is good, nice to have a backup for later. Next guess would be TSSM module.
  9. dhorne
    258
    i had that trouble with the TSSM but it was with my injected UC and it wouldnt supply fuel ,
  10. Hoople
    Hoople Account Removed
    7,198
    34
    Slow down, get a schematic & Buy a Multimeter.
