Stator Plug
Discussion in 'Electrical' started by zoood, Apr 19, 2010.
  1. zoood
    zoood Junior Member Product Contributor
    663
    5
    34881.1
    I had used my original stator from the 1993 EVO. I installed it in the new 113 Ultima engine I put in my trike. The rubber gromet on the stator , from it's exposure to heat and oil and age of 58,000 miles. Made that plug swell up in size. I had to shave it's size down in order to get it through the casing's opening for the stator plug. Unfortunately,... it leaks a little oil through there. Is there a new plug that I can purchase to stop this problem? Or am I stuck with having to buy a new stator? I had already tried a marine silicone. But as the engine warms. The oil still seeps by. Not a real lot. But its a new engine and I dislike oil leaks of any size.
    zoood
    50
    I have had good luck on the evo engines with the same problems using a small "O" ring that fits tightly around the plug and work it in around the plug into the case with a popsicle stick . Stopped the seepage for me.
  3. zoood
    663
    5
    On an easier note. Did you insert that "O" ring from the outside. I hate to have to take the primary cover off and have at it that way.
    RJ
  4. glider
    50
    Yes from the outside after unplugging the plug.
  5. zoood
    663
    5
    Thanks for that answer. Ill give it a shot. Other than that. Even though Im still doing the break-in on this new engine. Im sure glad I have a back-rest! This baby has a lot of power. Im impressed even by saying the least! Not even a quarter turn of the throttle and I'm movin!
    RJ
  6. glider
    50
    Let us know how it works out.:D
  7. Butch
    Butch Active Member
    227
    It works! Had a similar leak at the stator plug as well on my 99 tc88. Tried gliders solution and two years later I'm still leak free.
  8. glider
    50
    There ya go, proof positive it works :lolrolling
