free website stats program starts with kill switch | Harley Davidson Forums
My 2006 Low Rider started doing that a couple of years ago. It turned out to be a sticking starter relay that I replace for about $10. Good Luck
So, you're saying that if you kill the engine without using the kill switch by just turn the ignition off and then back on, then the start button works ok. Did I get that right?
Welcome to the forum from the southwest desert.
:nosad
With the engine not running, and the kill switch off, I can turn the ignition switch on, then when I turn on the kill switch, the engine starts without pressing the start switch.
