starting cold Evo
Discussion in 'Softail Models' started by Dustinthewind, Jun 11, 2014.
  1. Dustinthewind
    Dustinthewind Member
    I have a beauty 1990 FLSTC Evo.
    What is the best way to cold start these babies?
    thanks:shock
  2. fin_676
    5,775
    153
    284
    Turn on the fuel tap pull the choke knob fully out snap open the throttle 3 or 4 times (accelerator pump will shoot neat fuel down throat of carb) turn on main switch and press starter button
    Bike should start after one or 2 cranks if not release starter button snap throttle open 2 or 3 times and try again
    If bike starts and runs for a wee bit then stops repeat process till it runs
    Once running at a steady idle back the choke knob in to get the slowest run speed
    let bike warm up till heat can be felt on the rocker boxes (I put on jacket helmet sun glasses and gloves and mount bike during this time)
    Back off choke knob to a good idle pull in clutch for 10 sec select first and ride slowly away
    After about a mile push choke knob fully in after about 3 miles should be good to go
    Evo engines are not fully tight till it is fully warmed up and everything has expanded to full size, premature hard acceleration can blow cylinder base gaskets
    Once you get to know your bike you will have your own warm up procedure
  3. TQuentin1
    4,737
    142
    The way I start my '91 Dyna when it is cold is as follows:
    • Make sure tranny is in neutral
    • Turn on fuel flow at petcock
    • Pull out enricher handle all the way
    • Tighten up throttle locking star all the way and then back off until just free
    • Turn on ignition
    • Pull in the clutch handle
    • Press Start button to fire engine
    • Give engine a little throttle as necessary to keep it running between 1200-1500rpm
    • Slowly push enricher knob back in while compensating with throttle to keep engine running around 1200rpm
    • Lock the throttle with the locking star to keep the engine running at 1200rpm
    • Monitor the engine speed and adjust throttle as necessary to keep the rpm at 1200
    • Let the engine warm up until valve covers are nice and warm but touchable (about 3-5 minutes depending on air temp)
    • When the engine is warmed up, release the throttle locking star completely
    • Engine should continue idling at around 1000rpm
    • Ready to ride!!
    Warming up the engine EVERY TIME is very important on the EVO engine. This will extend the life of the base gaskets if properly performed.
    Cheers,
  4. Jack Klarich
    :D Brian has you covered here, that was my way with my Evos:s
  5. r_k_dragon
    r_k_dragon Active Member
    270
    4
    All the above is good, I had to hold the enricher/choke knob out to begin with since it would move in slowly on its own. That was only long enough for it to smooth out.
  6. TQuentin1
    4,737
    142
    You can tighten up the knurled plastic "nut" on the back of the bracket that holds the knob/cable. This is both the fastener and jam that increased friction on the cable and prevents it from retracting on its own.
    Cheers,
  7. Jack Klarich
    Be careful not to tighten any more than enough to put drag on the enricher, the plastic will break:s
  8. r_k_dragon
    270
    4
    ...and then you have to hold it out yourself. Caught me guys!
  9. TQuentin1
    4,737
    142
    Ha ha!! We've all done that!! I trust Jack was giving you the benefit of first hand experience. Me too!!
    Cheers,
  10. jimwis
    jimwis Member
    40
    Fin,
    You nailed it that is has and will always be my exact process.Well done old chap.
