hogrider91
Hi all, I have a 91 FXR evo. I've changed the Starter shaft seal 3 times now and for some reason it still leaks. Being an Auto Tech. by trade I know that I've put the seal in correctly and have done it just as if I were installing a cam seal in one of the many overhead cam engines I work on daily. Is it possible that maybe the Jack drive could be bent and while activating the starter it takes out the seal? Visually it looks OK...Anyways I bought another seal from H.D. and am getting ready to take it all apart again and if anyone has any advice as what maybe the problem I'd greatly appreciate it, cause when this sucker leaks it really leaks bad, especially after a hard long ride. Thank you for any info. in advance that may help cure this problem. Keep the shiny side up, and the rubber side down...
