mcooper101
i have a 06 ultra with v&h true duals, v&h fuel pak(which i hate) and a kn hi flow set-up(rk3909). my issue is the for the 2d time i am having oil weep out of the rear breather onto the upper 3 head fins. i have read and reread the mounting instructions and donot understand why you install a washer in between the head surface and the oring then the mounting bracket. i believe this is the area of the leak and am wondering if the right approach is to eliminate the washer and try the oring direct to the head. just curious if anyone else has had this issue and the solve. thanks.
moderator note: moved this post out of the Self Help section to generate more exposure.
